Discussion topic: Q Box - Reboot
Message posted on 01 Sep 2025 08:12 PM
Q Box - Reboot
I've started having to reboot my Q box and mini box at least 2/3 times a week
im having to power off for 30 seconds then restart the box
help!!
Message posted on 01 Sep 2025 08:58 PM
Re: Q Box - Reboot
help!!
Hi @Shipyork
Try a Reset Settings in the Q box hidden menu. See if that stabilises it.
