Discussion topic: Puck
This message was authored by: Twiglet23
Puck
Can you order a sky Puck for a spare room with sky Q, I have a a mini Sky Q in the other room multiroom? Thanks
Re: Puck
@Twiglet23
No. You can't mix and match your platforms. It's either Sky Q or Sky Glass or Stream.
Avatar for Twiglet23
Re: Puck
Thanks for the quick reply, I didn't think so but I thought I would ask.  Is there a way of watching sky Go on my TV through another device for the spare room or will I need another Sky mini box? Thanks
Re: Puck
Another mini - as you already have multiroom then you will only have to pay a one off cost (probably £50).
Check which main Q box you have as some early ones only supported 1 concurrent mini.  (Limit is 2 even though you can have 4 minis)
Re: Puck
I believe you may be able to do so using the Sky Go app on an Xbox or more awkward a Laptop with an HDMI output
As @PandJ2020 indicates SKY's preferred method is another mini (but see @PandJ2020 's note re limits)
Re: Puck
There are a number of ways you can use Sky Go via a TV, using devices connecetd to the TV, like;
Apple TV
Xbox
Playstation
Windows PC,  via a hmdi out cable connected to TV.
They may have the Sky Go app or TV from Sky app option.
Sky apps system requirements | Sky Help | Sky.com
They all work well when connected to a TV.
But best option would be to use a Sky Q mini with the TV.
Re: Puck
Thank you for all your support and replies I ended up ordering another Sky Q mini thanks.
