Discussion topic: Prompt that comes up while watching sky
This message was authored by: Leah73
I want to know how to stomp prompt that comes up on my sky
Re: Prompt that comes up while watching sky
What prompt?  Are you sure it's not your TV?
@Leah73  What does the prompt say, are you sure it's from the Sky Q box and not your TV?
If you advise what the message says the community can advise.
Hi @Leah73   What prompt, what exactly does it say. Prompts are normally from the TV and not the Sky Q box.
@Leah73
Typically messages generated from a television set need to be actioned, modified or removed using the television remote control rather than a Sky handset.
