Discussion topic: Programmes taking a few seconds to load/start.
Message posted on 04 Apr 2023 01:46 PM
Just recently some programmes or downloads are taking a few extra seconds to play. Or we get the 'wheel ' going round while we wait. Is this a box problem? Our internet is very fast so I can't see it's that. We have had our q box for a few years now.
Message posted on 04 Apr 2023 01:55 PM
							Re: Programmes taking a few seconds to load/start.
Hi @Kwdw
