This discussion topic has been answered Discussion topic: Programmes still recording despite removing series link
Message posted on 04 Oct 2026 03:06 PM
Re: Programmes still recording despite removing series link
sorry, i did not get a notification on your post... so im nearly a year late!
No, this isnt a situation where we've just watched a programme and then the next one downloads...
The situation might be that we watch an episode on saturday that was recorded the night before, we then decide we dont like it, so remove the series link and then the next friday the next episode records.
It is so frustrating. Any fix suggestions appreciated.
Message posted on 04 Oct 2026 03:47 PM
@Collinsc wrote:sorry, i did not get a notification on your post... so im nearly a year late!
Is this happening on multiple series? If so what channels are they on?
I have to say that there may not be an answer let alone a solution though, I keep having to remove literally hundreds of episodes of quiz shows that the wife has watched the odd episode of. This happens weekly.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 04 Oct 2026 03:49 PM
@Collinsc the response from @ozsat is what is happening and what you need to do
ie you set series link, it records on the Friday night after it records the Friday night episode it then sets up the recording for next Friday.
If on the Saturday you remove series link then as next Friday's episode is already set to record it records it and the series link ends the following week .
What you need to do after cancelling series link is to go into scheduled and then cancel the next weeks recording manually
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 04 Oct 2026 04:18 PM
"Is this happening on multiple series? If so what channels are they on?"... hmm i havent spotted a pattern but then havent looked out for one tbh. I will now though.
Message posted on 04 Oct 2026 04:19 PM
Thank you - ok i will try this next time!
Bizarre imo why you'd need to do that also. Surely "remove series link" should do just that.
Message posted on 04 Oct 2026 04:26 PM - last edited: 04 Oct 2026 04:28 PM
It does, but as explained in earlier posts the next episode is already scheduled to record.
Example:
- Mondays episode of xyz is recorded on series link
- After viewing it you decide you don't want to watch any future episodes
- Go into Recordings / Scheduled / find the next episode of xyz / scroll right and remove the series link (first) / then click on cancel recording
Message posted on 05 Oct 2026 02:10 PM
Language perhaps... but imo if you are clicking a button that says "remove series link" then it should remove everything, but there you go. Either way...
Thanks again - between a few of you i have now understood what you're getting at and i shouldn't get this issue again!
