Discussion topic: Programme unavailable message on SkyQ Mini box TV
Message posted on 05 Aug 2026 01:07 PM
Message posted on 06 Aug 2026 10:31 AM
Re: Programme unavailable message on SkyQ Mini box TV
Hi @CGB Welcome to the Community forum. Sorry to see that you've been experiencing issues with viewing programmes on your Sky Q mini box. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 09 Aug 2026 10:36 AM
Thanks for the private chat but problem still unresolved.
Message posted on 09 Aug 2026 11:47 AM
Message posted on 09 Aug 2026 12:11 PM
Just normal HD - no programmes are available - BBC, ITV, Sky, the whole lot...
Message posted on 09 Aug 2026 12:28 PM
hi @CGB
In the main Q box Home menu have you checked in Settings - Status to ensure Watch on Sky Q Mini box is ticked.
If so, have you carried out a Network reset on the mini box?
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 09 Aug 2026 01:14 PM
Yes, I've done all that before and no joy - and just tried again for completeness and again no progress.
- Thanks anyway.
