Discussion topic: Programme cannot be recorded
Message posted on 19 Apr 2026 10:55 AM
Why am I getting this notice? Why can't I record some programmes?
Message posted on 19 Apr 2026 11:04 AM
Re: Programme cannot be recorded
This happens occasionally. Leave it a few days to see if it changes if it's for next week sometime. Alternatively email the Viewer Relations Team at [email protected]
They can liaise with the channel concerned if it's not a Sky owned channel.
Message posted on 19 Apr 2026 11:40 AM
@Daisy+Pill wrote:Why am I getting this notice? Why can't I record some programmes?
We get this once in a bluemoon, turning off or unplugging the box for at least 30 seconds and waiting for it to reboot has always (so far) solved the issue.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 19 Apr 2026 01:02 PM
Thank you. I've now found the reason and sorted it.
Message posted on 19 Apr 2026 01:03 PM
Can you share as it might help others in the future.
Message posted on 19 Apr 2026 01:08 PM
Can’t delete recordings, can’t rewind, I hate my new sky box!
Since I've had this new box (which I didn't need) I can't delete recordings, I can't add or remove series links, I can't rewind live programs - I hate this box!
Message posted on 19 Apr 2026 03:07 PM
Re: Can’t delete recordings, can’t rewind, I hate my new sky box!
@Daisy+Pill wrote:Since I've had this new box (which I didn't need) I can't delete recordings, I can't add or remove series links, I can't rewind live programs - I hate this box!
Can you record shows now then? How did you resolve that particular problem?
Have you put the box into standby and then turned off or unplugged the box for at least 30 seconds?
Not a Sky employee
