Discussion topic: Product suggestion
Message posted on 22 Jul 2023 01:04 PM
							Product suggestion
I know the sky puck issue has been flogged to death it's just I have a suggestion that maybe sky can look at for us poor sky Q users.( not sure if it has been suggested before)
At the moment we have sky go which can tell that it is connected on the same network as the sky Q box which gives it access to the recordings, so isn't it technically possible to have a version of the puck firmware modified to only work when it can see a sky Q device on the same network? this would give us access to 4K to our other tv's that can use it.
Message posted on 22 Jul 2023 01:59 PM
							Re: Product suggestion
@Flamingo+Bingo wrote:so isn't it technically possible
Yes but it's clearly a commerical rather than technical decision.
