Discussion topic: Problems with satellite signals
This message was authored by: Deano16
I'm unable to view any of the BBC or ITV channels.
i can view channel 5 perfectly and som of the others.
i have reset the Q Box several times with no results
i have also performed a reset on the Q Box
can you help
Re: Problems with satellite signals
@Deano16
(Thread moved from Broadband board)
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
