8
This discussion topic has been answered Discussion topic: Problems downloading on demand or catch up
This message was authored by: Soozch53
I've recently came back to sky signature but I can't download on demand or catch up like I used to
Re: Problems downloading on demand or catch up
@Soozch53
Do you have the HD add on? If not please try changing the default download preference from HD to SD in:-
Main Menu > Settings > Setup > Preferences
If you do have the HD add on or the above does not fix the issue post again on this thread so we can potentially escalate your post to Sky. Sky will then try to refresh the viewing card which sometimes needs a couple of attempts.
This link explains more: https://www.sky.com/help/articles/call-to-upgrade-downloading-on-demand#q-help-articles
@Soozch53
Avatar for Soozch53
Yes I've added the HD on and have tried everything but still not working
@Soozch53
I’ll escalate your post to Sky in a few minutes (and update this post when I’ve done it) and the Messaging Team should contact you later.
@Soozch53 now escalated.
You need to watch out for a post from one of the team inviting you to a private chat and then you should see a blue/red speech bubble at the bottom of your forum page. You’ll have 48 hours to click on it and start the private chat or it will close automatically. If you fail to respond to a chat reply within 48 hours the chat will again close down automatically even if your issue hasn’t been resolved. Replies from Sky aren’t instant so you’ll need to check the chat thread fairly regularly.
This link explains what happens.
Avatar for Soozch53
Thank you
This message was authored by: Tom-W19
Thanks for escalating. We've sent an invite to @Soozch53.
Tom
This message was authored by: Stacey881
I am also having this issue after coming back to sky Q and i have HD already
@Stacey881
Before we go down the route of escalating this to the Messaging Team you could try refreshing your card yourself.
You can refresh your viewing card by pressing:
home > settings > system info > viewing card number > setup > viewing card setup
press select to trigger a callback
its not a callback on a phone but it's Sky terminology and this will be done over the internet.
If this doesn't help post back on this thread.
This didn't work sorry
Answered - Go to Answer
