Discussion topic: Problem
This message was authored by: weggy1000
Problem
My box keeps turning off even after turning off eco
Re: Problem
Hi @weggy1000
In ECO and Active the Q boxes will go into Standby after a period of inactivity.
If you set it to None then it is necessary to put the box into Standby with the remote when not in use.
https://www.sky.com/help/articles/using-the-standby-settings
Re: Problem
Turning off when?
