Discussion topic: Problem with sky box
This message was authored by: Holwell2298
It's saying on my tv - it looks like you do not have internet connection right now, been like it for two days tried resetting everything but still no good
Re: Problem with sky box
Hi @Holwell2298
Assume this is your main Q box?
