Discussion topic: Problem with sky Q box
Message posted on 26 Feb 2024 09:43 PM
When trying to watch programmes it keeps pausing and jumps back. We have reset box but this hasn't resolved issue.
Message posted on 26 Feb 2024 09:56 PM
Re: Problem with sky Q box
What did you do to reset the box @Bernie080176 ?
Was it just a reboot or a Reset settings ?
