Discussion topic: Problem with picture freezing
This message was authored by: Rita35
The picture/programme intermittently freezes. Including sound. This is only happening upstairs on the q box. Downstairs there is no problem.
Re: Problem with picture freezing
Mini box?
Avatar for Rita35
Yes mini box
@Rita35 wrote:
Yes mini box
@Rita35 Have you tried rebooting your main Q box ie
then reboting the mini box
Avatar for Rita35
Done several times and has made no difference
