Discussion topic: Problem with network connection
This message was authored by: Bailey55
Message posted on 03 Nov 2023 12:55 PM
I have sky multiroom. TV works fine upstairs (main hub) but not downstairs. Settings status is saying there is a problem with the network connection.
This message was authored by: Stephen+Mourton
Find out more
Message posted on 03 Nov 2023 01:41 PM
Re: Problem with network connection
Your wi-fi signal can be affected by what obstacles are in the way, most likely thick walls.
Did it work previously and gone off or never worked? If it hadn't worked previously try a wi-fi booster which just plugs into any electric socked somewhere between the two.
