Discussion topic: Problem with network connection on sky tv
This message was authored by: Sue1922
Every time I switch the TV on it says there is a problem with your network connection. I have to go into setting to reconnect to network. This happens every single time.
Re: Problem with network connection on sky tv
Hi @Sue1922
Are you completing the following.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
