Discussion topic: Problem with mini boxes
Message posted on
16 Nov 2024
06:34 PM
- last edited:
18 Nov 2024
10:38 AM
by
Kelsingra
Hi I live on Canvey island Essex can't get my mini boxes working what's wrong anyone having trouble ?😈
Moderator note: Changed title to reflect topic more.
Message posted on 16 Nov 2024 08:30 PM
Re: Sky Go previously worked - now get error message - We're having problems connecting you. Please
Hi @Tinkersuzie
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
