This discussion topic has been answered Discussion topic: Problem with mini box
Message posted on 04 Nov 2026 01:50 PM
I can't get my recorded programs on the mini box. Apps and normal TV are fine
Message posted on 04 Nov 2026 03:50 PM
@TerryFlinn wrote:
Since then the screen advises that it can't link with tv1.
@TerryFlinn
Is that a message generated from your TV which could mean your TV’s not seeing the Sky box on the relevant HDMI input.
Message posted on 04 Nov 2026 02:14 PM
Re: Problem with mini box
Presumably you aren't trying to watch a UHD recording on the mini box?
Message posted on 04 Nov 2026 02:28 PM
No. Up to Monday every recording worked fine. Since then the screen advises that it can't link with tv1.
I have tried rebooting without success
Message posted on 04 Nov 2026 03:43 PM
@TerryFlinn when you say you have rebooted did you reboot your main box first
then
Reboot the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@TerryFlinn
Message posted on 04 Nov 2026 04:46 PM
Hi Daniel
Thanks for helping however I seem to have solved the problem by deleting all the retained programmes. I suspect the storage may have been too much for the mini box
Message posted on 04 Nov 2026 04:47 PM
Nothing is stored on the mini box.
Message posted on 04 Nov 2026 04:51 PM
Hi Laing
Thanks for your response. However I have solved the problem by deleting all the recorded programmes. I suspect storage may have been too much for the mini box
@Laing1 wrote:
@TerryFlinn wrote:No. Up to Monday every recording worked fine. Since then the screen advises that it can't link with tv1.
then
Reboot the mini box
Message posted on 04 Nov 2026 04:55 PM
- I suspect the mini box may have attempted to upload all of the programmes but that is just a guess. I have successfully recorded a programme on the main box and viewed it on the mini box so somehow the system has corrected itself.
Message posted on 04 Nov 2026 06:05 PM
Hi @TerryFlinn The Mini box does not store anything, in computer terms it is a thin client with no storage facilities. Everything is streamed from the Main box.
