Discussion topic: Problem with home screen
Message posted on 25 May 2024 07:35 PM
Hi , I've non home display showing, so where all the apps normally are Netflix, Disney etc when you first turn your tv on aren't there , I've checked my network and it says it can't connect ? My WiFi is fine and I've turned the tv off and router and started them both again and it's still doing it ?
Message posted on 25 May 2024 07:57 PM
Re: Problem with home screen
Hi @Andrea51
Message posted on 25 May 2024 08:12 PM
Ok thankyou, i don't have a wps button on my router only a reset button ?
Message posted on 25 May 2024 08:14 PM - last edited: 25 May 2024 08:15 PM
all routers have a WPS button.
If you are trying WPS you must be on Sky broadband.
See router WPS button below
Message posted on 25 May 2024 09:06 PM
Ah it's there!! Thankyou for that I literally looked all over the router and couldn't see it haha 🤦🏻♀️
Message posted on 25 May 2024 11:26 PM
It's pretty discreet!
Message posted on 26 May 2024 09:43 AM
Done all of the above this morning and it's worked, thankyou for your help
