Discussion topic: Main Q box will not connect to broadband
Message posted on 25 May 2024 12:50 PM
Tried everything I can find on
line still won't connect
Message posted on 25 May 2024 01:35 PM
Re: Main Q box will not connect to broadband
Hi @Bunny43
Reboot the mini as above.
Message posted on 25 May 2024 02:03 PM
Tried all the above . Thank you.
Main box will not connect to network. I have tried multiple resets .
Message posted on 25 May 2024 06:15 PM
Hi @Bunny43
Message posted on 25 May 2024 06:37 PM
Hi bunny I'm having same problem I rang sky they are blaming my broadband as usual which I know is not the problem been working from home all day using my broadband
Message posted on 25 May 2024 09:51 PM - last edited: 25 May 2024 09:52 PM
If you've got a mini try powering that (or them) off completely and then doing a network reset on the main box.
Message posted on 26 May 2024 06:36 AM
I've already tried this but still not working.
thanks for the reply
Message posted on 26 May 2024 01:20 PM
Tried all suggestions , thanks to all who have tried to help. Still no joy.
Booked an engineer. Luckily they can send one out
in only 5 weeks! Not long now eh!
