1
This discussion topic has been answered Discussion topic: Problem with dish
This message was authored by: Kerrym
Problem with dish
Error message saying no satellite signal
Re: Problem with dish
@Kerrym
If it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️following adverse weather wait times for an engineer will probably be significantly longer
▪️I AM NOT A SKY EMPLOYEE ▪️
@Kerrym
Answered - Go to Answer
