Discussion topic: Problem with SkyQ
This message was authored by Guernsey1 This message was authored by: Guernsey1
Problem with SkyQ
Hi my skyQ box keeps turning on and off. I have unplugged it for 5 mins (several times) and I have turned off the echo saving.  Any ideas please?  Kevin
Re: Problem with SkyQ
Hi @Guernsey1
