Discussion topic: Problem solver
This message was authored by: Reg22
Problem solver
The tv picture has a dark band across the top with a thin white line and on the left side, above the line is a symbol  and HDM1 Sky Q.  Below the line, Stereo 3840x2160p
On the right side, below the line, the time 18.54, the time I turned the tv on.
Re: Problem solver
It's not the Sky box doing that - it's your TV...
Re: Problem solver
Hi @Reg22   Definitely sounds like a TV information display, but upload an image would reveal all.
Re: Problem solver
hi @Reg22
As the others ays it sounds like the TV's info banner.
Try using your TV's own remote which will have an i or info button
This message was authored by: Me134
Re: Problem solver
I had similar the odd few times when the Q box would only wake up to a black screen, sounds like the HDMI issue (presuming that is what causes it). Turn it off at the wall for 30 seconds and back on @Reg22
Not a Sky employee
Sky Q with 2TB UHD box wired to the Sky Max router
Sky FTTP 500Mb to Max Hub
