Discussion topic: Problem joining network error code mr102
Message posted on 13 Mar 2024 06:41 PM
Had Internet issue 2 days ago sky helped resolve but now issues with TV problem joining network error code mr102. Tried rebooting router and boxes no joy.. Went thru automated instruction and made apptmt for 25th March.. What am I to do till then
Message posted on 13 Mar 2024 07:20 PM
Re: Problem joining network error code mr102
Hi @Marrandia
Assume this is your Main Q box.
