Discussion topic: Prime buffering
This message was authored by: Rachel1976
Message posted on 05 Jun 2025 09:15 PM
Prime buffering
We've recently upgraded to full fibre and yet having issues with apps like Prime and YouTube buffering. Seems weird considering fibre should be a better service?
This message was authored by: hrai
Message posted on 06 Jun 2025 09:24 AM
Re: Prime buffering
Should be but network connections are a bit like witchcraft.
My suggestion would be to reset the Sky Q network connections and see if that helps. (There's a reason why "have you tried turning it off and on" is a thing! )
PS If you're using WiFi try to use Ethernet if possible.
