26
This discussion topic has been answered Discussion topic: Prime Video Removal
This message was authored by: debbiesharron
Prime Video Removal
How do i remove the Prime Vidro App from my Sky Q
I like Nat geo wild and slow motion forward and rewind options
This message was authored by: nigea99 Answer
Re: Prime Video Removal
hi @debbiesharron
I am afraid you can't remove (ofr for that matter add) any apps from SKY Q as what is included is governed by SKY updates
Is there a specific reason you want it removed ?
Would just logging out help you ?
hi @debbiesharron
Avatar for debbiesharron
Level 4 icon
@nigea99
Hi, Thankyou for your reply .
Would logging out of it make it dissapear
@nigea99
hi @debbiesharron
All apps will remain available even if logged out
This message was authored by: bob1234
@debbiesharronWhat is the actual problem as unless you go into apps you don't see it and there are loads of useless app which you just have to ignore.
@nigea99
No. You can't get rid of it.
I assume he suggested that in case you were concerned about kids racking up bills on chargeable content.
Level 4 icon
@Chodley , I would like to Filter out Apps that are of no interest to me,
Ie kids being one of the reasons
@Chodley, I would like to Filter out Apps that are of no interest to me,
I know. You can't.
Level 4 icon
Chorley,
Atchually you can ,
Settings , Kids , Pin
That hides the app?
Level 4 icon
@Chodley , Yes that is what i would like to do with Apps i do not need
@Chodley, Yes that is what i would like to do with Apps i do not need
We seem to be going round in circles. You said that already.
I said you can't.
You said "oh yes you can via the kids/pin menu"
I asked does that do what you want?
You said what you want again.
Level 4 icon
Chodley, I was told by the Sky Forum ( The people who are suppose to have the knowledge) If it was possible to filter away Sky Q apps ,
I was told NO ,
So i searched on Chrome ( Which appeared to have more KNOWLEDGE 🤔)
And contradicted what the Sky Community was Advising me ! So it seems YOU CAN INDEED !
I was told NO ,
Try it and let us know if it works.
Hi @debbiesharron
Adding a pin will not remove the App from the listings.
However it will ask for the pin if you try to use it
