This discussion topic has been answered Discussion topic: Prime Video Removal
Message posted on 17 Mar 2023 01:56 AM
How do i remove the Prime Vidro App from my Sky Q
Message posted on 17 Mar 2023 06:47 AM
I am afraid you can't remove (ofr for that matter add) any apps from SKY Q as what is included is governed by SKY updates
Is there a specific reason you want it removed ?
Would just logging out help you ?
Message posted on 17 Mar 2023 08:31 AM
							Re: Prime Video Removal
Hi, Thankyou for your reply .
Would logging out of it make it dissapear
Message posted on 17 Mar 2023 08:45 AM
All apps will remain available even if logged out
Message posted on 17 Mar 2023 08:48 AM
@debbiesharronWhat is the actual problem as unless you go into apps you don't see it and there are loads of useless app which you just have to ignore.
Message posted on 17 Mar 2023 08:53 AM
@debbiesharron wrote:Hi, Thankyou for your reply .
No. You can't get rid of it.
I assume he suggested that in case you were concerned about kids racking up bills on chargeable content.
Message posted on 17 Mar 2023 09:05 AM
@Chodley , I would like to Filter out Apps that are of no interest to me,
Ie kids being one of the reasons
Message posted on 17 Mar 2023 09:06 AM
@debbiesharron wrote:@Chodley, I would like to Filter out Apps that are of no interest to me,
I know. You can't.
Message posted on 17 Mar 2023 09:09 AM
Chorley,
Atchually you can ,
Settings , Kids , Pin
Message posted on 17 Mar 2023 09:10 AM
That hides the app?
Message posted on 17 Mar 2023 09:14 AM
@Chodley , Yes that is what i would like to do with Apps i do not need
Message posted on 17 Mar 2023 09:16 AM - last edited: 17 Mar 2023 09:35 AM
@debbiesharron wrote:@Chodley, Yes that is what i would like to do with Apps i do not need
We seem to be going round in circles. You said that already.
I said you can't.
You said "oh yes you can via the kids/pin menu"
I asked does that do what you want?
You said what you want again.
Message posted on 17 Mar 2023 10:13 AM
Chodley, I was told by the Sky Forum ( The people who are suppose to have the knowledge) If it was possible to filter away Sky Q apps ,
I was told NO ,
So i searched on Chrome ( Which appeared to have more KNOWLEDGE 🤔)
And contradicted what the Sky Community was Advising me ! So it seems YOU CAN INDEED !
Message posted on 17 Mar 2023 10:16 AM
I was told NO ,
Try it and let us know if it works.
Message posted on 17 Mar 2023 10:18 AM
Adding a pin will not remove the App from the listings.
However it will ask for the pin if you try to use it
