Discussion topic: Power cable
Message posted on 30 Jan 2026 04:56 PM
Power cable
Just had replacement sky q box delivered, but there was no power cable supplied and the power cable that I have is different to the one needed for the new box
Message posted on 30 Jan 2026 05:01 PM
Re: Power cable
Hi @Anniex5
If the box you had had replaced is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply.
Which part are you missing.?
See below.
Message posted on 30 Jan 2026 05:08 PM
Re: Power cable
Am missing the multi pin Din cable, I have the figure of 8 but it isn't the correct power cable for the box I have been sent
Message posted on 30 Jan 2026 05:19 PM
Re: Power cable
Hi @Anniex5
Afraid In hindsight you needed to check that the replacement box had the power supply and din cable included if the Q box had the orange coded multi pin din socket in the back of the Q box.
All you can do now is speak to Sky.
Message posted on 30 Jan 2026 05:22 PM
Re: Power cable
Thank you, have spoken to Sky and they are sending me a replacement power cable but feel it will be the same as I have and not the one I need.
Thanks for your help
Message posted on 26 Jun 2026 05:40 PM
Re: Power cable
I know this is a long time since you posted this, but did they send the power cable. I am in the same situation, phoned them and they said they would send one but I've heard nothing since . They said 5 days and it's been 3 . Thought they would have confirmed it by email or something
