Discussion topic: Portable sky box
This message was authored by: Shellcharlie72
Portable sky box
We have a caravan and I was wondering if I was able to obtain a second sky q box that can be used with a portable sky dish?
Re: Portable sky box
@Shellcharlie72
No. A Sky system can only be set up at a permanent address and the viewing card only used at that one address.
@Shellcharlie72 also in addition to @Daniel0210 advice you will not be able to get a second Q box from Sky as you can only have 1 main box per account any Q boxes you see for sale will be classed as stolen goods as Sky only loan the boxes to you and they must be returned to Sky
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Sparkymatt100
What you may be able to do is get a multiscreen add on and then use either a console or laptop with Sky Go connected to the TV using HDMI in the caravan.
You may have to use a mobile hotspot or get a mobile broadband router for the Internet and use WiFi tho.
LG OLED65C3" 4K HDR TV
Sky Q 2Tb HDR
Mini Box
Sky Full Fibre 300
