2
This discussion topic has been answered Discussion topic: Poor sound
This message was authored by: anita+db
Poor sound
Hi  I have a
SAMSUNG S90D 48 inch OLED 4K HDR Smart TV - QE48S90D  - I have tested all the sounds and resets on the TV standalone and it appears when I'm plugged into sky Q the sound on recordings and playbacks is really really poor and I'm having to switch my TV up to 38/ 40 on the volume side. This doesn't seem right to me ,  the TV works okay without sky attached to it so appears it's the skybox that's causing the problem Any ideas please?
This message was authored by: MightyQuinn Answer
Re: Poor sound
Hi @anita+db   What audio format have you set your Sky Q box to output? Home -> Settings -> Setup -> Audio visual -> Digital audio output HDMI. You could try changing this to see if the audio improves. Is this a new TV, I.e. did it work okay previously.
Re: Poor sound
Avatar for anita+db
Level 2 icon
Re: Poor sound
Thanks , tried that suggestion however it's worse on that setting so changed back to normal
