Discussion topic: Poor quality & broken picture
This message was authored by: Patriciaclegg
While watching I get broken & distoughterd picture
Re: Poor quality & broken picture
@Patriciaclegg
Live or on-demand?
Which television platform?
Avatar for Patriciaclegg
Re: Technical fault
It says I have no satellite signal
I have done all the trouble shooting help & support but still the same
Re: Technical fault
@Patriciaclegg
Sky Q or Sky+?
Depending on which you have will depend on which advice we give you.
(it's not a broadband issue)
Now no signal & no blue sky q blue light & one green light nothing else
@Patriciaclegg
You seem to be having various issues.
No signal and no satellite signal issues are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
