7
This discussion topic has been answered Discussion topic: Poor RTE2 and TG4 signal
This message was authored by: Patsy-C
I have good satellite signal and hi speed broadband connectivity. However, I have poor signal on RTE2 and TG4 only with pixelated picture and poor sound. Any suggestions?
Re: Poor RTE2 and TG4 signal
@Patsy-C
Yes
This message was authored by: nolte
@Patsy-C
What sky system do you have? Sky stream sky glass, sky q etc?
ROI sky Q Customer.
Avatar for Patsy-C
Sky Q
@Patsy-C
The Internet broadband should not have an affect on reception on sky q, as the channels are carried on satellite,  unlike Stream or Glass.
Pixellation might be caused by some interference on the frequency in signal. Is there similar issues for virgin 4,  u&gold, sky sci-fi, or u&alibi?
Is the pixellation constant? Or at some times?
ROI sky Q Customer.
Avatar for Patsy-C
Just checked now 1pm Jun 23, and ALL channels are streaming perfectly. It is an intermittent issue. It was very poor reception last night which is a real issue on RTE2 for World Cup games!!
@Patsy-C
If there's a slight dish misalignment then it will be more susceptible to rain scatter.
Avatar for Patsy-C
OK, thank you. So should I now contact Sky to get the dish alignment checked?
@Patsy-C
Yes
