Discussion topic: Pixelating sky mini
This message was authored by: stevied1971
Pixelating sky mini
I've been getting a lot of pixelating on both mini boxs. The main box is working fine. I've tried reboot, unplug ect. I have sky fiber. Any help would be appreciated.
Re: Pixelating sky mini
How far are the minis from the next closest bit of sky kit (router or Q or booster if applicable)
sounds like wifi interference
Avatar for stevied1971
The mini in the kitchen is no more than 15ft away from the main box and the other one is upstairs.
15ft should be pretty reliable unless there's something solid and metallic in the way
I'd try a network reset on that kitchen one and get it to WPS connect to the Q box and see if that makes any difference.
I've tried all that already 👍🏼maybe it's time to get onto sky and see what they can do about it.
Thanks for your reply.
I'll escalate this so they will invite you to an online chat
This message was authored by: Tom-W19
Thanks for escalating. We've sent an invite to @stevied1971.
Tom
