Discussion topic: Pin troubles
This message was authored by: posty1
Pin troubles
For some reason my sky is asking for my pin on every channel even though pins not been set, in settings pin is off for all Chanel's, it's a pain in the butt.
Re: Pin troubles
Try a power cycle of the box.  Some channels will have Mandatory Daytime Protection regardless of your settings.
Re: Pin troubles
Hi @posty1   If the mandatory PIN was removed, then Sky would then be required, by law, to only transmit post watershed programming after 9pm and not during the day as present. Only required on live and recorded content.
Using Parental Settings on Sky Q
