Discussion topic: Pin number reset not working -
Message posted on 22 Nov 2024 06:27 PM
Pin number reset not working - ive tried last 4 digits of my viewing card and last 4 numbers of my bank account - niether work on the reset
the last 4 digits of the viewing card does work on the channels
Message posted on 22 Nov 2024 06:58 PM
Re: Pin number reset not working -
Message posted on 22 Nov 2024 07:25 PM
Yes - as per my detailed description - it doesnt work........
Message posted on 22 Nov 2024 07:52 PM
Hi @MM44
Your detailed description doesn't help @MM44
There is no mention of using the last digits of your Viewing card to Reset your pin.
The last four digits of your (original) viewing card is the default pin unless you have changed it.
Certainly the last four digits of your bank account (which is used to pay your Sky Subscription ) is mentioned.
If you have been completely through the link I posted (including watching the video) and still can solve your issue then you will need to contact Sky directly.
Message posted on 22 Nov 2024 08:28 PM
sorry - i will precis my initial listing as it would seem to have ben unclear
........... ive tried last 4 digits of my viewing card and last 4 numbers of my bank account........
Message posted on 22 Nov 2024 08:49 PM
Hi @MM44
My last post stands. If you have been completely through the link I posted and cannot solve your issue you need to contact Sky directly
Message posted on 21 Dec 2024 02:40 PM
reset pin
