Discussion topic: Picture out of focus
This message was authored by: Dimma
We have two TV's and one the picture is out of focus
Re: Picture out of focus
Hi @Dimma
You could try rebooting the Q box but it could be a TV issue;
Avatar for Dimma
Thannk you. I have tried this. Today we had a new Sky router positioned in a different place to the previous and I wonder if the signal is not strong enough?
@Dimma
A main Sky Q box does not use an internet connection for live television: this comes from the satellite dish feed.
A Q Mini box may well be using local Wifi to pick up its data from the main Q box.
Hi @Dimma
I have removed your first post as it is unnecessary to post two threads on the same issue.
I assume that you have a main Q box and a mini.
Which one is giving the issue?
Avatar for Dimma
The main
@Dimma wrote:
The main
Hi @Dimma
If this is happening on live satellite TV it could be an issue with the TV set.
Is it at all possible to try swapping the TVs round just to check the TV is not the issue
Avatar for Dimma
Thank you will try that
By out of focus, do you mean blurry? If so turning up the sharpness slightly may help it look clearer.
