Discussion topic: Picture not clear
This message was authored by: Gnoelie
Picture not clear
Hi , I recently bought a new LG 55" smart tv . I have set it up to sky Q box but sky channel screen isn't 100% . Small Menu screen is very clear and defined but when I go back to main screen picture isn't as clear . I've tried all the picture settings on sky . Apps such as Netflix and YouTube are perfect. Any help would be appreciated.
Re: Picture not clear
Are you watching HD channels?  (Or SD?)
If the latter then on a 55" TV it will look atrocious.
Avatar for Gnoelie
@PandJ2020 , watching in HD
Ok, should be fine - can you post a picture of it?
