Discussion topic: Picture freezing
This message was authored by: Shaun73
Picture freezing
Picure keeps freezing whilst watching a recorded programme and streaming. Have tried recommended fixes ie rebooting and doing a software update.
Re: Picture freezing
Hi @Shaun73
