Discussion topic: Picture break up resulting in technical issue
This message was authored by: Crickt+Fan
Hi, in the last few days I have been having picture break up. Most times it goes away but sometimes it results with a statement saying there is a technical issue with this channel. It is happening on several channels. It is not signal strength which shows a signal quality of 90 and signal strength of 80. Any ideas?
Re: Picture break up resulting in technical issue
Hi @Crickt+Fan
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
