10
This discussion topic has been answered Discussion topic: Picture break-up on Channel 5 HD
This message was authored by: djpalmer
When ever I watch or record anything on Channel 5 & their assciated channels I always get at least one instance of picture break-up part way through. It lasts for around 5 to 10 secs. It's only on Channel 5 no other channels.
To clarify I'm watching Channel 5 via Sky Q. I have no other way of watching.
Anyone else experience the same problem?
Avatar for djpalmer
This message was authored by: djpalmer Answer
Re: Picture break-up on Channel 5 HD
The issue was solved by eventually having a new LNB, new cables and new Sky Q box.
This message was authored by: Mr+Flibbles+86
This message was authored by: Fredleted
Yes, this happens to me. It just happened watching channel 5 drama Coma
Avatar for djpalmer
Thank you for your reply. It can't be all 3 (LNB, cables and Sky Q box) and why does it only affect channel 5?
Avatar for djpalmer
Sky initially replaced my LNB but the issue was still occurring. Engineers came back and decided to replace the box and external cabling from the dish.
The LNB wasn't that old. Can't remember if it was replaced when I upgraded to Sky+ or if it was also replace when I upgraded to Sky Q.
The cables where pretty old as well.
Why it only affects Channel 5 I'm not sure. Maybe their signal is not as strong as the other channels.
As you can see from this thread someone from Sky put me in contact with the engineers. You might have to do this yourself.
This message was authored by: Lozzy26
Mines the same it's getting on my nerves
Avatar for djpalmer
See my previous Answer. May contact Sky ask for an Engineer and point them to this thread.
This message was authored by: Trelowen
Same here, CH5 keeps breaking up. Sky are becoming useless like they were in the late 90's and 2000's
Avatar for djpalmer
Have you contacted Sky and submitted a fault report. Sounds like your equipment NOT a broadcast issue.
Have'nt got time today, free all day tomorrow so I will contact them
