Discussion topic: Picture Issues after buying new TV
This message was authored by: Kate8
Hello, I bought a new TV and the picture quality is terrible now.  The picture isn't sharp and sometimes blurry.  Do I need a new Sky Box?
Re: Picture Issues after buying new TV
No, you will almost certainly need to adjust the picture settings within your TV setting menu.
Avatar for Kate8
Many thanks but I have tried the settings.  Live TV is clear but when I use Sky then it's blurry.  don't know what I can do as Sky will not pick up phone or reply to my messages.
This message was authored by: Invisiblename
Not sure what you expect Sky to do, as the problem seems to be associated with your replacement tv.  If it was working ok with the old tv, everything suggests it is something to do with the new tv's settings.  Sky do not provide tv specific support.
I am just another Sky customer!
Avatar for Kate8
Hi, I know that. Sounds like you work for Sky! It is fine when watching live tv but when I watch through Sky it's blurry so it may be the box.
what do I expect Sky to do? Maybe pick up the phone or answer emails occasionally??
Hi @Kate8   Did it work okay with the old TV? If yes, then it your new TV, nothing to do with Sky. Have you checked the usual, different HDMI lead, different port on the TV. Have you set the resolution on the Sky Q box to match your new TV ...
If you still have the 'old' TV try that and see if the problem goes away.  That will eliminate the Sky box as 'faulty'.
Avatar for Kate8
Thanks all but the last TV wasn't good quality so I couldn't tell anyway.
Are you watching SD or HD channels?
Free advice given by a fellow Sky customer - take it or leave it, I don't really care.
Avatar for Kate8
Nice. Perhaps don't be rude when someone asks for genuine help. Have a great day, hope you feel better.
No rudeness intended, was just trying to help.
This message was authored by: Doc5907
@Kate8  find it strange you saying Sky aren't answering your call. There may be a wait but the call should be answered eventually so I wonder what number your calling.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
On the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number for Ireland.
Say 'technical' when prompted, stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Maybe if you posted an image of your 'blurry' screen it might help us figure out what the issue is.
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for Kate8
Hi there,
I'm not sure what's so strange for you.  Sky is notorious for not answering or bothering to get back to customers.  I do not have sky mobile, nor sky talk line.
The 0333 is precisely the number I am calling and after waiting 25 mins it says your'e busy and to call another time.
No one has answered my email either.
Many thanks, and yes, I have photos of the TV picture but would very much like not to have to communicate with you over a public forum.
@Kate8 wrote:
Hi there,
Not much point in continuing this then is there.
Sky Q 1TB UHD
LG TV
Sky Mobile
