Discussion topic: Patchy reception
This message was authored by: Sean1705
Patchy reception
My reception is very patchy but my WiFi is perfect
Re: Patchy reception
Hi @Sean1705
Do you mean your Q box connection to your Router is patchy?
Avatar for Sean1705
Thanks for the reply. The sky reception is patchy. Sometimes the picture will be fine but then the picture will be patchy and the sound goes
