Discussion topic: Parental pin
This message was authored by: Janey13
Parental pin
I must have forgotten parental pin so I can't watch certain recordings. Help please!
Re: Parental pin
Check out this guide
Hope it helps!
Re: Parental pin
hi @Janey13
It is usually the last 4 digits of your viewing Card
See Home - Settings - System Info
to view it
If that doesn't work
try
Home - Help - Reset PIN
