Discussion topic: Parental controls
This message was authored by: Ged163
Parental controls
I have disabled all the parental controls on my skybox however I still have to put in a pin number on certain channels and movies before the 8 o'clock watershed
can you help
Re: Parental controls
can you help
hi @Ged163
When SKY Atlantic & other channels show certain material before the relevant 'watershed' it will always be present & you cannot turn it off
https://helpforum.sky.com/t5/Sky-TV/Is-there-any-way-I-can-turn-this-damn-parental-control-off/ba-p/...
Our advice is to set the PIN to something like 1111 to help enter it when needed
