Discussion topic: Paramount +
This message was authored by: Andrea33
Paramount +
When I signed up to sky cinema I was told I could get paramount + for free, I've signed up and tried to log in and I'm not able to, it does say that the paramount + is connected to my sky account but I've never been able to watch anything. Could you give me some advice on getting it sorted out, many thanks Andrea
Re: Paramount +
Hi @Andrea33
Assume you first subscribed to Paramount plus through Sky Marketplace?
https://www.sky.com/help/articles/sky-marketplace-subscribe-to-apps
Avatar for Andrea33
Re: Paramount +
I did, and it states I paramount + is connected to my account but when I try to login it won't allow it
Avatar for Andrea33
Re: Paramount +
I also followed all the directions given to me by sky
Re: Paramount +
Hi @Andrea33
Did you then get this screen?
"If you’re eligible for Paramount+ at no extra cost as part of your Sky Cinema subscription, the price will show as £0."
Avatar for Andrea33
Re: Paramount +
To be honest I think I did, if it was conn to my account then that should be the case shouldn't it
Re: Paramount +
Hi @Andrea33
I cannot say whatever you did.
The next step would be to create an account .
Scan the QR code on your smartphone or tablet. Or go to sky.com/paramountplus-activate.
Sign in with your Sky iD and create a Paramount+ account.
You then sign into Paramount p,us using the Emaiil and password you set up for paramount
