Discussion topic: Paramount+
This message was authored by: Elsi20
Paramount+
Trying to sign into paramount + using my email  and sky password .but saying details invalid can anyone help
This message was authored by: kevin70
Re: Paramount+
I had to sign in with new login details, not sky login. good luck.
Avatar for Elsi20
Re: Paramount+
If you do that do they charge you .
This message was authored by: best+of+the+best
Re: Paramount+
@Elsi20 as long as you have Sky Cinema they won't charge you for changing your logging in details
Sign jnto Paramount Plus from a web-browser
Choose your profile then click on the three lines too left
Select your name then select account
On the next screen you can edit email clicking that will send you a link to change your email.
If you click edit password just follow the on screen instructions
Just change your password to start off with if that doesn't solve it change both email and password.
This message was authored by: Dallen9798
Re: Paramount+
@Elsi20
Have you added Paramount+ to you Sky account and then created your Paramount+ account?
Please follow these steps carefully: https://www.sky.com/help/articles/sky-marketplace-subscribe-to-paramount-plus
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
Re: Paramount+
@Elsi20 you need to follow the instructions in the link below which also include creating a paramount+ account if you haven't followed the instructions and just clicxk sign in and use your Sky details nothing will work
https://www.sky.com/help/articles/using-paramount-plus
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
