Discussion topic: “Because of a technical issue your download couldn’t be completed.”
Message posted on 21 Apr 2023 06:37 PM
"Because of a technical issue, your downloads couldn't be completed. Please try again later." Based on other posts here, I've changed my settings to download in SD only. I'm still getting the above message. I also tried multiple times - based on advice here. Can anybody help. I've also tried restarting the box.
Message posted on 21 Apr 2023 07:16 PM
Re: “Because of a technical issue your download couldn’t be completed.”
Hi,
https://www.sky.com/help/articles/because-of-a-technical-issue
Follow these steps to resolve.
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
Message posted on 21 Apr 2023 07:54 PM
Hi @Dallen9798 I did the first fix, now having switched back on the screen is reading "No signal."
i tried pressing the home button and switching off at the mains but this hasn't changed anything.
Message posted on 22 Apr 2023 08:16 AM
Once you've reset your settings, as it says you need to repair your remote.
Press the amber light on the front of the Sky box which will turn it on
Then point the remote at the box and hold down the numbers 1+3 together at the same time to pair the remote.
Message posted on 22 Apr 2023 11:03 AM
Hi @Dallen9798 thanks for this! I managed to figure out the remote issue myself and eventually got it re-paired.
Then the Apps had disappeared - fixed that with "Refresh apps" in the settings menu.
(Sadly none of this has fixed the first problem box refusing to download, which is a bummer🙁)
Thank you for your help and advice 👍
Message posted on 22 Apr 2023 11:13 AM
Hey, youre still getting the message about the download failing?
If so you'll have to do the next step which is a hard drive reset
Message posted on 22 Apr 2023 12:37 PM
(Sadly none of this has fixed the first problem box refusing to download, which is a bummer🙁)Thank you for your help and advice 👍
@Kat654 before doing a hardd drive reset You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
