Discussion topic: Paramount plus down tonight?
This message was authored by: grayuk
Paramount  just gives start screen and that is it..Had no trouble up till now. All other apps work
This message was authored by: inasnum
Re: Paramount plus down tonight?
Yep same here.
This message was authored by: MrBoo1
Me too. Have shut down everything and restarted but no joy. All other APPs working.
Avatar for grayuk
Level 3 icon
I did..sort of get in..said something about new features...then locked up again...
hi @grayuk
I just tried going in via my computer & got a server failure
This message was authored by: DSSavvy
Yes - app not loading on mine either - either black or blue screen, also weird white line appeared across the screen.
This message was authored by: bruce12
Same here also smart tv app spin circle sky q blank app iPad crash website does not work
This message was authored by: michelle7911
paramount plus wont load
i cant get past blue screan with parqmount plus  on it
Re: paramount plus wont load
hi @michelle7911
I have moved your post to an existing discussion regarding this - it does appear to be down at the moment
This message was authored by: ARLaxey
Paramount Plus showing 0 seasons on all shows.
Tonight I log into Paramount Plus and every show listed shows 0 season and nothing is watchable
I have unplugged the Sky Q box and plugged it back in.
I have tried to view through the Paramount Plus App and the same nothing is available to watch.
Re: Paramount Plus showing 0 seasons on all shows.
If I try to stream a show that shows it has episodes it gives me Error Code 1100 and then returns and shows the show has 0 seasons.
The only place I don't have the issue is logging into Paramount on a web browser.
This message was authored by: Invisiblename
P+ working fine for me this morning
I am just another Sky customer!
This message was authored by: Garry+Colling
I can't get passed the profile page
Avatar for grayuk
Level 3 icon
I had that as well, I just rebooted the sky box and it was sorted.
This message was authored by: Hantsxlg
the Paramount PLus app since last night will not work on either my stream pucks. I can get as far as trying to watch a programme but then just get a blank screen with the 'loading' spinning wheel. Same behaviour on both pucks, which I have rebooted and refreshed apps on. Everything else works fine.
Is anyone else experiencing  issues?
