Discussion topic: Paramount Plus
This message was authored by: Emma1972
Paramount Plus
The Paramount Plus page is not letting me activate it.  Saying "we are having problems with this page.  Please try again later".  Has been saying that for the past 3 days!!
Re: Paramount Plus
If you have Sky+HD (where you've posted) there's nothing to activate. Paramount+ content is available in the Catch Up & Sky Cinema sections on your box.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for Emma1972
Re: Paramount Plus
Not true - I have subscribed through SkyCinema but when I got into anything on Paramount it asks me to activate my account and then tells me that my details are incorrect!!  I have tried resetting password but am not receiving any emails of links to reset.  I'm completely stuck and paying for a service that I'm not getting.
Re: Paramount Plus
@oj01 is perfectly correct. Are you sure you're trying to use Paramount+!on a Sky+HD box?
Avatar for Emma1972
Re: Paramount Plus
Yes - and the technician that came from Sky said all I had to do was activate and it would work but it doesn't
Re: Paramount Plus
@Emma1972  When did you get your Sky TV box installed?
Avatar for Emma1972
Re: Paramount Plus
In September 2024
Re: Paramount Plus
@Emma1972  In that case you won't have a Sky+HD Box as Sky have not installed these for a very long time, you will have Sky Q
Re: Paramount Plus
Sounds like you have not activated correctly.
Follow the advice for Sky Q in this article;
https://www.sky.com/help/articles/using-paramount-plus
