12 Sep 2023 09:02 PM
Just connected a Panasonic TX50MX650B to my sky q box and it asks what picture setting to use 1080 or 2160 uhd and ultra HD can anyone explain the difference and which would be best.
12 Sep 2023 09:08 PM - last edited: 12 Sep 2023 09:09 PM
Posted by a Superuser, not a Sky employee. Find out morehi @Viking465
I have my SKY Q set to 2160 10 bit for my Panasonic GZ950 but I do have the UHD subscription to make th emost of it.
If you don't have the UHD subscription & doen' want to use the apps for UHD, you may find the TV upscales 1080 better than the SKY Q box does
If you want to set to 2160 10 bit & the SKY Q box won't set it let us know & we will try to advise what settings on the TV to check/change
